Enjoy your adventure GordonCleaned and lubricated rear corner steadies
replaced rear yellow flasher bulbs ( getting white looking)
lubricated and released door locks ( lack of use me thinks)
released grey water tap( stiff ) even though it's nylon
tomorrow list to go through as per swmbo wants done afore we get away for a few weeks from friday
Crumbs Gordon, why was your LPG so expensive?Garage loaded up and cycles strapped in
fuel filled into diesel tank
filled up lpg £1*49
shifted items in cupboards and new matting fitted in bases
Bought a new coffee percolator and ground coffee( brownie points?)
also some alchol purchased
bought some provisions for my ridgemonkeys![]()
Tantallon really is too expensive - we're quite happy outside the treatment plant on the beach.Enjoying a pleasant stay at a CCC THS near North Berwick. Only £7 a night. Lots of vans going past the end of the road to pay a fortune to park at Tantallon Campsite.
I recently had to do much the same to my omnistep the alloy rail on one side had broken and was only loosely bolted.Set out to replace the habitation step warning buzzer and after trying to find out online where it is located I saw several posts relating to the earth wire on the micro switch being corroded. Under the van I went to check out, sure enough it was white so bored out the rivet but had to remove the outer casing to reattach the earth wire, phew. When I was undoing the casing I noticed the pinion shaft that operates the arm to push the step out and in was squint, when I finally managed to free the cover I noticed that the servo housing was cracked where the pinion gears are housed. Geezo.
The step always had a droop in the time I have had it which I had put down to wear but on further inspection when weight is put on the step the pinion is pushed sideways due to the broken casing. To resolve this I have bored through the outed casing and tapped the mating side, I now have a 6mm Allen bolt through the step through the outer casing and threaded into the end cover. I now have a firm step but still no warning light and still have not managed to located the buzzer.View attachment 59381View attachment 59382View attachment 59383View attachment 59384
