Update, CrashData took delivery this morning of the backlog of ecu units from Royal Mail, including ours, but still no technicians due to Covid, so a trip to Liverpool to retrieve the unit and its now on the way to Morecambe to an alternative repairer .......watch this space 🤔🙄🤞🏻
Just refitted the airbag ecu, all faults cleared and repair turned around in 48 hrs including shipping, great service.
I got in touch with Phantom as the ultrasonics keep tripping the alarm system. It's already been turned down, so next thing, I guess is to replace the unit. Luckily we aren't using it and I know how to enable the alarm without the untrasonics.
You're now tilting to the other side I see. Any reason for switching?
That was an old picture David they have tilted the other way for a long time.
ah, ok. But ... reason for the original switch then? wanted the hab door side to face the sun?
Put washed bedding etc back in, put tools away after fitting new leisure batteries yesterday. Now all ready for 2 week trip up the west coast of Scotland next Thursday.
After experiencing the cold Southern night air last weekend we purchased a firepit and fitted the bullfinch quick release gas outlet. 20210903_125355.jpg
Cable tied wheel trims back on, removed yesterday to check wheel bolt torques. Gave wheels and trims a wash.
Now attempting to resolve battery state of charge display issue as charger on float, voltage 13.0 volts + but % display showing 78%.
Apparently a common fault after changing batteries. Found a thread on a forum explaining to remove certain fuses, leave for 3 hours then refitting should resolve the problem. Fingers crossed it does.
