Interested in doing this...where it it purchased from, thanks Chris.
I done all the chassis legs and right along the sill s Fred + gas tank + i have enough left for next year and the year after lolololDid you do the inside of the chassis as well ? When under the motorhome I was a bit surprised how open the chassis legs are.
Inside door skins and sill plus a & b frames.I done all the chassis legs and right along the sill s Fred + gas tank + i have enough left for next year and the year after lololol
I was surprised on how little was used and I bought 5 ltr but intend on doing the pickup as well.I done all the chassis legs and right along the sill s Fred + gas tank + i have enough left for next year and the year after lololol
Yeah your right it goes a l9ng way for sure .I bought the 130 quid kit so got a bit spare lololI was surprised on how little was used and I bought 5 ltr but intend on doing the pickup as well.
Yes ive done all then Trev .Inside door skins and sill plus a & b frames.
I had engine battery voltage drops 12 months ago, even with a new Yuasa Battery, when the Van was not used very much. Solved the problem with an AMT12 Battery Refresher/Charger from David at Wildebus. It has 8 charging combinations plus a 9th, user connectable via a fitted spare cable, that forces the Leisure Battery to supply 3 amps to the Engine Battery for 9 seconds in every 10, so no risk of a flat battery. And it's not asthough you're short of Solar/Lithium power ... AMT12 was £65 plus fitting and was the best bit of kit I've boughtChecked my eng battery levels .
After speaking with sargent yesterday disision was to bypass sargent to charge eng battery.
As was getting a big drop in battery power over night..12.9 11.8 average
So bypassed last night ..
Went bed 12.9v this morning 12.7.
Alarms set so can except .2 drop.
Not a great lover of smart charging on ec500.
My new solar array for lithium is also bypassing ec500.
Happy days I hope.
Hopefully we are sorted but if not I will take advice on board.thanksI had engine battery voltage drops 12 months ago, even with a new Yuasa Battery, when the Van was not used very much. Solved the problem with an AMT12 Battery Refresher/Charger from David at Wildebus. It has 8 charging combinations plus a 9th, user connectable via a fitted spare cable, that forces the Leisure Battery to supply 3 amps to the Engine Battery for 9 seconds in every 10, so no risk of a flat battery. And it's not asthough you're short of Solar/Lithium power ... AMT12 was £65 plus fitting and was the best bit of kit I've bought
Why they can't coordinate and work together beats me, boils my pee when they lay a new road surface and some clown comes along and digs a track all the way down the new surface.Completed the abandoned flushing of the Fresh Water Tank on the 'rinse cycle'. Scottish Gas Network ['SGN'] are replacing the Mains, and, as I began to fill the Fresh Water Tank yesterday, a contractor strolled up with a 2 stroke Disc Cutter, spraying tarmac, 2 stroke and brick fumes everywhere. We have a Plague of Gas Engineers who have dug lots of holes in the A921 over about 300m, because they are ahead of the program, whereas the Installation Team are behind schedule, and nobody, least of all SGN, has a clue when the Installation and the Remediation Teams will return to the Project Plan. The fact that the Fibre Broadband Engineers are working about 100m away from the SGN furthest outpost, approaching from the opposite direction, closing the gap, makes the Broadband Engineers a racing certainty to rip up what will be the newly repaired road surface ...
'The Nymphomaniacs Guide to Project Management: Straight from One Cock Up to the Next' springs to mind ...
In thirteen years of cable laying I only experienced this once and that was pure coincidence.Why they can't coordinate and work together beats me, boils my pee when they lay a new road surface and some clown comes along and digs a track all the way down the new surface.
The glue is only sitting a a surface of paint or get coat, mine are bolted through and well sealed, screws would be ok but use stainless ones.Started cleaning roof
Plastic solar panel feet sticking them down with sikoflex 522 is it best to screew as well .
And seal the screews tops to.
Some say do both Some just stick.
