You will be of devoid testicals Mr ex tester!!
I was thinking the same Terry lolololYes of course I did Jeffrey, the owner has a family to feed and keep a roof over their heads. Unlike yourself, I couldn’t sleep at night known I was being a financial burden.
I wouldn’t be surprised your man shops at the local food bank, his Bairn’s wearing clothes from a charity shop, you will burn in hell Jeffrey!!!
Finally given up on fixing my Truma 6002 Combi boiler. Over the last three years it's had a full strip down and clean over the gas side, a new 12v circulation fan, two new electric heating elements, and two replacements of the power transistor (which feeds the circulation fan) on the main PCB.
The two previous transistors lasted a good few months, putting off the inevitable, but the one fitted yesterday failed within a few minutes and now I've lost any remaining faith I had in it.
New Truma 4E heater ordered today, booked in to be fitted next Wednesday.
Pm’d you Steve ref controller.Replaced the KS Energy 120Ah Lithium Battery with a 230Ah Roamer Under Seat Lithium and upgraded the MPPT Controller to Victron 100/30. If anyone needs a 75/15 Victron MPPT Controller, I have one going cheap!
Watch a guy on YT call Mispronounced Adventures and he promotes Roamer batteries, he does artic winter trips upto northern Sweden, Norway and Finland so his batteries get well tested.Replaced the KS Energy 120Ah Lithium Battery with a 230Ah Roamer Under Seat Lithium and upgraded the MPPT Controller to Victron 100/30. If anyone needs a 75/15 Victron MPPT Controller, I have one going cheap!
Surprised you would have any imperial sized gas pipes installed? I would think they would be either 8mm or 10mm? I got a cap for my (Thetford) fridge gas supply from B&Q. Nice and simple.I tried to replace rear wheel speed sensor for ABS. Gave up after the sensor stuck in the hole and I didn't have it in me to remove the handbrake drum to pull it out that way. My friendly mechanic will do it next week.
Made progress making the cabinet to fit the new Thetford oven above the new Thetford compressor fridge after tossing everything marked Dometic. I am working out how to prevent any possible gas leakage from entering the cabin and figuring the gas connections from imperial to metric.
You sure it’s not 30mbar? I thought the 50’s were on old vehicles but I probably have that wrong, thought Europe had standardised on the 30mbar before my van was built. Give Charlie a shout at Autogas 200, he will advise if you need assistanceWell the manual states 8mm inlet at 37
mbar for propane. "When all else fails read the manual". I'll go out and look for metric gas fittings. I think my German motorhome has 50mbar regulator. I might have to get smaller jets. I expect it will be OK though just have to adjust to hotter oven at standard settings.
