looks good :) checked for any metallic vibrations?
We travel with about a dozen tea towels, and only use a maximum of 2 for drying dishes.
We also use the economy model of storing 2-3 toilet rolls in the bathroom cabinet and storing toothpaste, toothbrushes, medicines etc inside the cardboard inners to maximise the storage space and stop all the tubes/jars flying off the shelf when we open the cabinet on arrival ... :ROFLMAO:. And there's also the advantage of having a new toilet roll close at hand ... [we are of a certain age, where this type of consideration is important ...]
Is this lack of storage space a symptom of smaller vans then? I run round with empty cupboards and lockers, I could easily overload by a tonne if I filled everything 😂😂😂
We have spare teatowels and a loud radio we sing to 🤔😉😀
. . . . . . . and when you are not in the shower singing what do you use the spare teatowels for?
Today:
I removed a tin of Ambrosia creamed rice from a cupboard.
And then I looked at my LB wiring, figured out what was making it get too warm for comfort and decided what to do about it. A/S haven't fitted fat enough cable to put enough oomph (that's a Very Technical term) into the LBs.
Stopping rattles andrew! They are jammed in the oven and grill and hob and sink
I realised that, I was imagining you in the shower singing, and coming out wrapped in tea towels.
Now I'll go and take a mild sedative . . . . . . :oops:
Especially the cassette, Neil? :ROFLMAO:.
There's no denying that a 5.99m M/Home, however good the design, will have compromises on space and storage, and, if, like me and my alter ego Justin Case, you carry too much kit, the problem gets worse. Using the toilet roll inners to store the lotions/potions/pills etc is part of the solution to the compromise!
One of the reasons for upgrading the cupboard was the hinge screws went into the edge of the pressed and glued paper which was only a centimetre wide so every time you opened the door it worked lose I have upgraded the hinges to household one 36mm instead of 20 mm and also fixed oak batons to the carcass which allow a much better fixing
Great job Andy
