Do you get much tyre noise?Asked and answered:
I have not noticed any difference but then I had them put at the back and my original Continetals at the front. One thing I do like is a smoother ride at a much lower psi. The down side to this is it has upset my TPMS which is something I need to get sorted.Do you get much tyre noise?
You are running BFG All Terrain on the rears only?I have not noticed any difference but then I had them put at the back and my original Continetals at the front. One thing I do like is a smoother ride at a much lower psi. The down side to this is it has upset my TPMS which is something I need to get sorted.
Yes, I appreciate that as a front wheel drive van I am not getting much benefit out of them but the original tyres have enough tread left on them that i want to wear those down some more before upgrading the front ones. I had the rear ones moved to the front.You are running BFG All Terrain on the rears only?
what have u done with the bumper. ok.pjI have been putting it off since I bought the van in November but today decided that the towbar just HAD to come off. I will never tow with the van and have no intention of adding a bike rack, so... Off it came!
Was not a bad job and the bolts and nuts all unscrewed easily. I have left the 7 pin connector still wired up and tucked away behind the bumper for now. I might keep the towbar as it might be of interest to a prospective buyer at some point in the future? But I might offer it for sale on the bay...
The whole lot came to around 32kg which is a useful addition to my available payload.
So, what did YOU do to your van today?
K![]()
This thing has two functions. One is the blue light zapper, so far untested with unwilling victims, but produces 560v across the coil. The voltage reading was taken this morning after leaving the second function, warm white night light, on for in excess of 12 hours.Looks ideal but could be a slight problem with that depending what the numbers means?
USB powered, which means 5V.
5W at 5V should mean a current of 1000mA (1A), which is ok for a typical socket, but they state 4000mA (= 4A).
If it does pull 4A that will be too much for most USB Sockets so you would need a higher current-capable version (readily available and not expensive so not a problem).
A draw of 4000mA at 5V would make it a 20W unit and when I was looking at these, before I thought of just adapting the one I had, I did see quite a few 20W devices, so it could well be that power? (it could of course be 4000mA at 1.25V. That would make more sense for the charging side as well)
Just a potential heads up.
After a full charge and running for thirteen hours the coil voltage went down from 580v to 380v. Never claimed a scalp though ...Be interesting to see the results.
Don't get a lot of flies and beasties in the van but the zapper I have I am not convinced it is not a CO or a Buddist and refusing to take a life.
No Picture showingInstalled my bigger fridge -
Hmm, don’t know why the photo is its side!
just arrived in time as we’re off on a little jaunt down the Western Highlands this evening![]()
