Fitted new fan to Thetford toilet .Priced the fan from Thetford they wanted £59.95 .I got two off eBay for £4.50 ....talk about a rip off the fan is only 40mm square.
Yes, my PVC has one of those too. We've become used to hitting the flush button twice. The second time to turn off the filtered fan, unless, of course........A fan on a toilet?
Have to admit I never knew moho toilets had fans. Is that to get rid of the stink?![]()
Seriously though, what is the fan for?
Yes your right it’s to get rid of the smells lololol.A fan on a toilet?
Put the gear back in the cupboards but now better organisedhttps://motorhomer.com/threads/what-did-you-do-to-your-van-today.38423/page-153#post-226891
A few months ago I popped into a local Joiners and they ripped me a long strip of Plywood from a spare sheet.
Added Shelves to three of the lockers in total
Nice one HaroldMOT passed with two advisories. Slight corrosion on exhaust and vehicle underbody. That'll do for a sixteen year old vehicle.
Cheers
H
Good workshop Gordon. £280 for service, including brake cable and linkages, grease of suspension units on rear axles, oil and filter and a drop of gear oil and a CV joint changed to correct an ABS fault. Full price MOT at £54 as well. If you've found a good un stick with eh?Nice one Harold![]()
Don't think that is a costly repair in any way sounds great value imhoGood workshop Gordon. £280 for service, including brake cable and linkages, grease of suspension units on rear axles, oil and filter and a drop of gear oil and a CV joint changed to correct an ABS fault. Full price MOT at £54 as well. If you've found a good un stick with eh?
Cheers
H
On my first motorhome mine came with clips for mounting the handle, mind you I only used the awning half a dozen times in 18 months of owning the motorhome hence haven’t had one fitted to present motorhome.Made another tweak yesterday which was handy
I really hate rattles (not a good idea to own a Motorhome really if you hate rattles!) and I also want things I use handy and not have to dig around for stuff.
The Awning Handle in my van has no place to go and tended to live under the seat with a bunch of other random stuff on top so found a new rattle-proof home for it ...
A pair of Pipe Clips (think they are 22mm?) at the bottom were just right in keeping the pole tidy but available inside the wardrobe
And one at the top (28mm this time? Used whatever I had and happened to fit) to keep the the handle secure.
Any kind of clips could be used - I used the clips I did as I had them already in my plumbing box, but just dead useful having the pole right to hand![]()
I’m a happy camper !Unfortunately reversed into a low grass bank after missing my turnoff and when I pulled forward head a loud noisethankfully no damaged panels, just Looks like things are slightly out of alignment, it has 2 corner panels with the indicators etc and a centre panel Will have a look when home at end of week and if it’s a major strip down will get dealer to do it when in for fitting cycle rack in 2 weeks.
