Low wind speed = low voltage (ie not enough to be higher than the battery voltage level).
Unlike solar power, the volts AND amps rise at higher speeds. This is a basic fact for ALL wind turbines. Either that bloke has been conned by the makers or he is getting paid a lot of money to fund his next ascent somewhere.
My wind turbine (a Rutland 504) was rated at 80 watts. That was rubbish as well. Possibly in a test chamber but not in the real world.
A further complication is the effect of height above ground on wind speed.
The Meteorological Office measure wind speed at a height of 10m, whereas the height of the axle of the Texenergy Infinite Air 18 Wind Turbine is about 1m.
The wind speed over land decreases dramatically as one approaches the ground, mainly due to friction but also due to other effects, for example turbulence. The magnitude of the decrease depends on the 'roughness' of the surface, with smooth open sea having the lowest practical roughness. Fields, slopes and hedges are really not good news!
I'd expect a wind of 40mph measured at 10m to be more like 4mph at 1m on a typical inland surface (I've assumed a log relationship, but a typical power relationship gives a similar figure).
The Texenergy Infinite Air 18 Wind Turbine is likely to need an uncomfortably strong wind to generate maximum output, but Scotty's practical experience of the device is what is really needed here.
Colin
