trevskoda
And apply copper slip to the back of the pads, stops that eratating sqweel.Did you clean the area where the pad lug fits into the caliper? A wee rub with a file works.
Only if you have left it to late, you should change pads when 3/4 worn.Perhaps I'm out of date, but when I've changed my disc pads in the past it usually meant I needed to fit new discs too.
Continuously glue edge strips for cupboard doors and drawers back in place. It looks real bad without them because of the laminated polystyrene sandwich construction. It seems HYMER builds use 10 year lifespan products.
I also replaced the fresh water pump as it was talking too loudly and annoying fellow campers. I didn't get the right replacement so had to do some heath robinson. My wife likes it because the flow is less and she finds it easier to adjust the shower temperature.
I had a customer who found his waterpump was too lively with his Lithium Battery and its 13V+ voltage.I am thinking about getting a lower flow and pressure pump. Bit scary though because if you get it wrong the toilet won't flush and it's money down the drain.
At least if it doesn't flush you can put your hand down and remove the moneyBit scary though because if you get it wrong the toilet won't flush and it's money down the drain
I used an electric eel plus my metre to trace the fault; because there's no plaice like ohm ...My loo and flushing, so next job tmo is find the fault, ohm/volt meters at dawn.
...... Drove to the Bell Inn, Belbroughton.......The man is a star .........So, if you're heading for Newhaven Ferry, the pub is 182 miles north of the Port, and only 2 miles to M5/M42S, and about 5 miles of M5 J3, heading down A456 to the Hagley Bypass.
I was born in Stourbridge, and visits to Client Hills (esp. Boxing Day sledging) we're a regular feature! I told the Manager of the Bell Inn that I had attended the Xmas Dinner Season in 1979 with my colleagues from Crawley Heath branch of the Bank, and he replied, tactfully, that that was before he was born ...182 miles north of Newhaven might not be a strong enough draw to attract Motorhomers ......but........
The Clent Hills are only 3 miles away, 1,000,000 visitors can't all be wrong, and they are free to visit.
That makes the Bell Inn at Belbroughton (with it's huge car park) a great place to stop, so thank you for me !![]()
'Cradley Heath', not 'Crawley Heath' ...I was born in Stourbridge, and visits to Client Hills (esp. Boxing Day sledging) we're a regular feature! I told the Manager of the Bell Inn that I had attended the Xmas Dinner Season in 1979 with my colleagues from Crawley Heath branch of the Bank, and he replied, tactfully, that that was before he was born ...
We bought the obscure label similar step from Leclerc Hypermarché in Miranda d'Ebro in early May for €32.99 [about £28.50] and use it to get into the drop down bed. Ours has 2 treads and a top deck platform, giving an overall height of 65cm and the same footprint. The extra height means we can leave the bed at the height that is just about flush with the lounge seating, saving the night/morning routine of chucking the upholstery around to stop the bed fouling on the cushion seatbacks etc. The short height makes it easier than the Hymer Ladder to stow on top of the bed when travelling, and as a 2nd use, the operating height is just bout erfect for lifting the ebikes and Bike Cover on and off the Bike RackDoing a few tweaks to the Motorhome experience ... not so much DOING actual things to the van, but more changing how I am using it ...
Thought the Microwave was broken when I tried to use it at Druridge so ordered a replacement from Amazon. Turned out the Microwave was fine but the supply had no Neutral supply (which my NCV tester would not pick up on and I thought the supply was good all the way into the oven - lesson learned there!).
But new Microwave has 'flatplate technology' - which means no annoying turntable to deal with- and a grill, which I think will be handy to be able to do things like heat pasties and also crisp them up a little. New one was 1cm wider which meant had to modify the Tambour doors and rails in order to allow them to open wider to slot it in, but fingers crossed was worth it
Also, despite old and new both being 800W Microwaves, the old one drew 1170W in use and the new one draws 1050W, so actually seems quite a bit more efficient for some reason.
I can't remember the last time I used the gas oven in the built-in cooker - I use an Air-fryer - and the same goes for the gas grill as well - especially with a grill within the new Microwave - so put some cloths over the metal insides to make it anti-rattle and is now my full-time pot & pan storage
Next addition is a double-step to get in. I don't have to much of an issue with the single electric step (although it is far from perfect having said that) but the OH with her little legs finds it a bit awkward. Looked at double-step options ... replacing the electric single with a double electric one is just too pricey so dismissed that and the typical caravan double step is ok for a caravan, but for a motorhome I thought it would get in the way as take up too much room and get in the way, when inside between stops.
I found this folding step on Amazon which looked ideal and decided to go for it
Nice deep treads and the dimensions meant it is an equal height between the ground and each step and the internal step in the motorhome. Not the cheapest step, but seems pretty solid and when folded up it fits neatly and out the way behind the drivers seat so not in the way when not needed.
This step is available sold as Kampa and Maypole, but I chose one with some odd German name for £45 - link here
Final thing for the day was sorting out my Mesh Firepit... Didn't notice until Druridge, but the bolts that keep the legs on the frame were too short for the nyloc nuts to properly secure and one after another fell off!Replaced the bolts with longer ones so the nylocs would stay in place, plus some washers to make positioning the legs more solid. I would suggest anyone with a mesh firepit like this check the bolts are long enough to do the job...
actually, that is a thought ... could use the step by the bike rack to lift them on and off and make it a bit easier.We bought the obscure label similar step from Leclerc Hypermarché in Miranda d'Ebro in early May for €32.99 [about £28.50] and use it to get into the drop down bed. Ours has 2 treads and a top deck platform, giving an overall height of 65cm and the same footprint. The extra height means we can leave the bed at the height that is just about flush with the lounge seating, saving the night/morning routine of chucking the upholstery around to stop the bed fouling on the cushion seatbacks etc. The short height makes it easier than the Hymer Ladder to stow on top of the bed when travelling, and as a 2nd use, the operating height is just bout erfect for lifting the ebikes and Bike Cover on and off the Bike Rack
That's exactly what we do, David. The difference between the bikes from a single step of 19cm and the new step of 65cm is chalk and cheese, and it's also considerably easier to hook the Bike Cover on and off!actually, that is a thought ... could use the step by the bike rack to lift them on and off and make it a bit easier.
