SquirrellCook
Just spent an hour annoying the neighbours sanding Betty's roof.
I too would be keen to know how to remove the vent for cleaning, please.
Davy
I watched that before cleaning mine. Simple job if you have a thin T25 torx wrench.
I had to replace EHU inlet on my 2004 van recently and it was bedded on something like this - still perfectly malleable.Without knowing the circumstances of this application, I doubt anyone could advise. However, there is a generic "correct" sealant.
What I'd use is some form of non-setting butyl sealant: the stuff that's like sticky blutac, but white. It comes on a roll with a backing release paper. Quite expensive, but it lasts for decades without going hard, getting stiff or cracking.
Unfortunately I don't remember what its brand name is.
Remember, you are looking for a sealant, not an adhesive. You want it to stay flexible and waterproof forever.
I do hope that was a joke. Silicone is useless for this. It WILL leak in time.Of course I replaced with with a modern white silicone!
Yes, that's exactly what I am advising. It's horrible stuff to remove, but well worth the effort.Well it wasn't silicone but it was a modern 'sanitary' sealant.
Are you advising that I take it off and start again?
I wonder why these modern sealants will work on a range of building materials many of which are the same as on motorhome but not on motorhomes themselves?
They only work well if you choose the correct sealant. Silicone sealant mastic rots wooden window frames, for example.I wonder why these modern sealants will work on a range of building materials many of which are the same as on motorhome but not on motorhomes themselves?
As far as I recall, you pull the opening and closing knob straight off, undo the (four?) screws round the edge of the grille from underneath, then you can remove the inner frame, which lets you access the screws that hold the clamps that grip the roof.What about my kitchen roof light with extractor, is there something similar to this?
