SquirrellCook
Had a nice evening meal with Anita sat in Murky. British cow pie in Brasschaat Belgium
Pass the marmalade honeyBought a folding table from Leclerc for outside eating. The non folding version was 80cm long, too big to store safely, so we bought the folding version of 2 x 60cm halves. Like sitting at a baronial feasting table ... It's ok when the baguette is intact, because we can pass it like a baton; but as we eat chunks off it, the need for longer arms bevomes evident
Nice one Paul .Don't know about you but I get really pissed off with the window trims when they have shrunk in the sun and they take the short cut across the corners. After sitting and staring at the skylight trim for weeks I decided I needed to do something about it.
Before :
Having watched you tube I decided to mark the screw locations with masking tape and to remove each fitting one at a time and insert the new trim before fixing the fitting back using the original holes.
I worked my way around the whole skylight until back at the start and just overlapped the ends by about an inch and cut so they were under a fitting and screwed down.
Hopefully this will last a good few years before it starts to cut corners again.
Along with the trim I purchased a trim insertion tool as recommended by the suppliers Seals Direct. I couldn't get on with the tool and ended up using a plastic wedge trim tool. Anyhow the skylight looks a whole load better and I can now stop staring at it !
Paul
Just the one Gordon lolololThink on my backend ,got a skateboard to rest ma butt oan when I'm wobbling along
Well done Annie great news.I sold my van today woohooooo.
Looks neatFinished cutting and installing the carpet.
That can be tricky.Looks neat
I've been contemplating removing the carpet from the MH bathroom and fitting vinyl but the awkward bits around the loo is putting me off![]()
