Had to look that one up
Freedom
Freedom
The Irish gaelic spelling.Had to look that one up
Freedom![]()
'sore arse' = piles, so piles of freedom?Sold it, going to buy a caravan and an electric bicycle!View attachment 64208
Are you sure you will be able to tow a caravan with an electric bike???Sold it, going to buy a caravan and an electric bicycle!![]()
One thing I do know...... I won't be getting a caravan.Are you sure you will be able to tow a caravan with an electric bike???
K![]()
Could you not put some large heatshrink over it?Sanded new gas bottle down so stone chip spray will key to it better i hope + fitted wood stand so i can get at all the bottle when i spay itView attachment 64215
Getting LPG tank envy now..Sanded new gas bottle down so stone chip spray will key to it better i hope + fitted wood stand so i can get at all the bottle when i spay itView attachment 64215
Not as daft as it first sounds... if the tank is exposed to road grit from front wheels, stonechip will give some protection but if very exposed I would be tempted to stick on some of that roof flashing, the sort with the very thin lead backed by bitumen,Could you not put some large heatshrink over it?![]()
Ill stick with 5he shieldNot as daft as it first sounds... if the tank is exposed to road grit from front wheels, stonechip will give some protection but if very exposed I would be tempted to stick on some of that roof flashing, the sort with the very thin lead backed by bitumen,
Not quite heatshrink but on the same lines.
K
Or a large alloy shield![]()
