Think of all the extra payload you've gained ...Finished cleaning the Motorhome roof, first time in the seven years we've owned her. Don't think it was done much before then either. Still need to go over it again to clear some black spots.![]()
I'm married to one, Wully ... Very low energy model, but still higher than my consumptionIce maker you need an ice maker. One of my unusual buys but great for drinks and keeping the cool box topped up.
I am busy doing mine now Robert and it may take me some time lololBecause of Covid and getting let down by a garage finally got my motorhome underseal done nearly 4 years of waiting
It's why God invented Vaseline ...After I discovered the little windows on the side of the overcab bed opened (took around a year to realise that), I then discovered opening was not a problem, but closing again was another matter
The little extending rod and sleeve jobby would stick when in the fully extended position and refuse to go in easily and eventually not at all. The last time it locked open I actually had to unscrew the rod from the frame so I could close the window, and so it stayed undone and closed for the last few months. Offending rod below ...
Removing the window and dismantling the assembly revealed a simple ballbearing and spring affair. Cleaning the ball bearing of the slight detrius that had stuck on it over the last decade or so, then cleaning the rod and reassembling it made it go in and out nice and smoothly. Repeated on the other window that was also sticking badly and jobs a good un
But if you take this apart to clean, make sure you are doing it somewhere you don't drop the tiny ballbearing!
So the moral of the story is (one for Marchie ....) giving the balls a good clean makes for a much better action of the rod allowing it to slide in and out without getting stuck.
What dia is the flex tube ?Last few inches of my exhaust has been missing (corrosion worm) since I have had the van. only effect noticable is old battery box is getting a bit sooty as the pipe ends directly below it and on Autotrails the underfloor lockers are open behind the skirting.
Decided today to fix it by sliding a section over the end of the old pipe and brought outside where it should originally end up (can't replace the entire pipe without replacing the entire exhaust silencer and multiple pipes at a few hundred pounds and it is still ok so unnecessary).
Used a section of flexible exhaust pipe that was left over from when I did the VW LT Exhaust system plus a U clamp, so fix cost under a tenner and it looks about the same as OEM except for the serrated finish.
14 inches is not a tip, David, that's a double allowance ... A candidate for circumcision if ever I saw one ...I looked for end finishers for the LT a few years ago but couldn't find one of the right diameter. This time, a tip wouldn't suffice - the section was around 14" long.
That's more modest [and less intimidating]Mine was just the last 5in .
