I heard it cost you a few drinks !You realise Wully will be after a set now, obviously in some royal tartan.
after i poured a pot of chilli over them at new year christine will need a new set luckily it was before i’d had a drink lol
Sorted new thermostat , just for your info I read thermostat can be affected by dust and may need cleaning ??? As we say in Sheffield bang a nuen on ,How is your heating working barry
Got to agree. After all the buggering about that I had,I wish I’d known about that particular wrinkle beforehand.Sorted new thermostat , just for your info I read thermostat can be affected by dust and may need cleaning ??? As we say in Sheffield bang a nuen on ,
Up yer erse sun!Sam did you check and read the instructions properly because I think you have got them the wrong way round there’s a tiny L for the left and a R for the right on the bottom that you won’t see now that you fitted them I’d take them back off and check if I were you.
The only thing I have had to cut was the excess threaded area on the link arm this was in the instruction book to remove, it also shows position to move the hand brake cable but there is no way there is enough excess to move and attach to the bracket supplied, I shall check again when I have the wheels on the ground.when i had the bellows fitted on mine there was a steel anchor plate for the seat belt that fouled the bellows when squashed it was that close i had to take it of secured by 12 long bolts through floor, bolt heads under boiler took them off cut away some clearance of the plate & refitted about 2 days graft
Get yourself an AMT12-2, Jeff, and have all that spare solar keep the Engine Battery topped up! You have the knowledge and skills to fit it yourself, unlike me, whose knowledge stops with the opening of the wallet ...Had to put battery on charge as it wouldn't start
Be careful when replacing it, if you have too. My back still gives me little reminders.Had to put battery on charge as it wouldn't start
