marchie
Elaine's got the same make of self-healing cutting mat for her sewing [minus the glue and other stains!], David. Olfa, IIRC. If I were to 'borrow' the mat for M/Home repairs, it would be the last thing I ever did; and Elaine's next project would be a custom made shroud for me ...Won't have much fun without greasy nipples
I remembered a couple of years ago I had some corrosion in the top marker lights due to a cracked lens. So decided to remove the lens to check size for replacements.
Looks like none available of the right size, which is a shame as this is what the lens looks like ....
Marker Lamp by David, on Flickr
Gave it a clean. Removed glue from a previous repair (before my time) and attempted a repair using Poly Cement (the stuff you use when making Airfix models).
Actually seems pretty reasonable.
Refitted and carefully screwed in bolts enough to secure but not enough to break it again![]()
But nice repair job!
