nabsim
Well in Shane’s van not mine but…
Checking electrics and found nothing 12V had a fuse fitted. Traced all cables and removed a carrier bag of cabling that wasn’t doing anything. Got water pump working that didn’t before along with tv aerial booster and a volt meter. Everything connected up through an old fuse box that was in their but not used.
Found and fixed a couple of the 240V sockets that had wires out
Connected the two hab battery’s together that only had -ve connected
Changed so solar passes through both battery and power takes out across both battery’s.
Lifted bonnet to check starter battery was in there to see how much cable will be needed for b2b and Shane spotted a pipe disconnected. Think it is the EGR but not 100%, (Citroen Relay). After Shane connected it up again the whistle had gone and he reports much more power lol
Everything now works as it should AND is much safer lol
That will hold it until we do a proper rewire
